Customer wants graphic on vinyl table
jtiii
I paid good money for you to read this!
Our local Fire Dept has round black vinyl tables in their lounge area that are going to be used for eating. They want an 18" round "In Memory of" graphic in the center of each. I don't think decals would be a good long term solution with the grain of the surface plus the wear and cleaning these tables are going to get.
I was thinking of maybe a thin sheet of (acrylic or polycarbonate?) with 2nd surface graphics but I'm not sure how I would affix that, especially in such a way as to keep liquids from being able to seep under.
Or maybe printed Sintra with a laminate...
Anyone ever tackled a project anything like this?
SightLine
We have - what we did to increase durability was to use a polycarb laminate that was cut 1/2" larger than the print. Learned that trick for doing long term floor graphics years ago. Tricky to setup and do though.
DL Signs
Never go against the family
Use a high tac vinyl designed for low energy plastics (3M, Avery, Oracal, Prizm, pretty much all have them), a polycarb or floor lam, and it helps to do like Sightline says to have the lam larger than the print.
jtiii
So do you know if 3M 3662 with their floor lam would be good? I won't be able to make the lam oversize though as I would be ordering it from 365
