Customer wants to cover Windows for temp.
what the
Owner/op
I feel like I am always using the wrong material when printing full graphics for Windows while the store is under construction. Is there a standard material specifically so I'm not over doing it instead of banner material or poster paper?
Thank you
GAC05
Quit buggin' me
I'd choose a material that is easy to install/remove and works well for the customer.
Something along the IJ35c or IJ40c depending on price.
It goes on easy with air release & comes off clean with removable adhesive.
C series of IJ has the gray glue to help with block out.
There is most likely another brand that is cheaper with the same performance - you need to look around - AirMark or something from BigFish (material merchant here).
You can find some dirt cheap crap vinyl but the problems you'll run into with install - staying up or not coming off without a mess will soon eat up any savings you might have counted on.
wayne k
guam usa
Bill Modzel
I've had very good luck with General Formulations Metro Mark. It prints beautifully on my HP26500 and applies easily although in hot sunlight is is a bit stretchy and should be pre-masked. The last job I did was up for 4 months and pulled off nicely without a bit of adhesive left behind.
Bigdawg
Just Me
We generally do poster paper and tape it in place. No sense doing a big ole install when these are just temp graphics. The price difference (for us) between adhesive vinyl and cheapo polypropylene and then installation of each is pretty significant.
