I have designed a PSP skin and made all the cut lines (shapes) with the pen tool in Photoshop CS3. I save as .EPS and then load it up in Illustrator CS3 and do the CutContour thing and everything is all great. The problem is when it comes to cutting this design (with versaworks) after printing it will first cut the outside cut line, then the next cut line, then the outside again, then the next, then the outside again, and it keeps repeating this until its done cutting everything. Of course I know this is bad as it is cutting the outside line several times when it only needs to cut once. Does anyone know what is going on here? Is there a way in photoshop to combine all shapes (paths) together before I even load it up in illustrator? Any help would be greatly appreciated.
