Cut multiple jobs
SameDay Signs
Probably a dumb question but i have a large order of decals to cut out and am trying to figure in flexi how to say cut 250 stickers at a time with contour marks and then have it repeat over without having to get up and manually put over next mark each time...I am using a summa 140d cutter
any help is appreciated
Old Timer
in flexi under the arrange tab near the bottom, step and repeat
bob
Step and repeat won't work UNLESS you don't use the quantity setting in Rip and Print or Production manager to specify your 250 images. You have to arrange all [250 in your case] images, each with a contour cut line, to send as a single job. Then set the quantity to the number of sets of 250 images you need. In the Advanced tab in the Rip and Print select Contour and uncheck the one set of registration marks for all images. This will then print a set of registration marks for each 250 image set. Make sure you have set adequate spacing between the images.
