cut paths from flexi 8 to versa works
shirtz
Hi
for some reasons my cut paths won't transfer from flexi 8 to versa works, they just show up as pink lines to be printed. It works coming out of corel, i dont understand the problem we're having. any suggestions?
thanks
yukon
In Flexi, the cut path has to be a "contour cut". If it's not, highlite the line and choose "make contour cut" under Arrange > Contour cut > make contour cut. Then send to Versaworks.
Hope this helps.
Yukon
DRamm76
Using the Contour Cut feature as opposed to the "pink lines" is always easier. You may also want to try exporting is an EPS rather than using the "send to versaworks" feature.
Also make sure your Queue A & B Settings under Format has the EPS margin @ .01. This will avoid any clipping of the cutline
