Cut Picture and Print (Newbie)
Discussion in 'Flexi' started by MCD4x4, Jan 27, 2006.
  1. MCD4x4
    MCD4x4 New Member
    11
    Hi Guys,
    I'm trying to print/cut a picture with a white background. I'm having a problem with it. If I follow the same steps that I have been with one color pictures it doesn't work. When I try to use Contour Cut, it's square because of the background. Any help would surly be appreciated. Thanks.
    Brian NY
  2. Fred Weiss
    Fred Weiss Merchant Member
    20,893
    535
    113
    Sep 11, 2003
    Olympia, WA
    Doubtful that you will get it to autotrace. You should be able to lay down a cutpath by hand with your Bezier pen tool.
    Do you know how to use the Bezier pen tool?
  3. MCD4x4
    MCD4x4 New Member
    11
    Hi,
    No, I never used it. I know to click it and highlight the image, bitmap-vectorize-bezier. By doing this I get the outline but the inside is getting messed up.
  4. Fred Weiss
    20,893
    535
    113
    Sep 11, 2003
    Olympia, WA
    You should click the pen tool and lay down some lines and curves on a blank page for practice. It takes a little practice but drawing your vectors in and doing a little touch up editing will result in a smooth, fast cutting path that will please you and make you wonder why you ever depended on autotracing.
  5. bob
    bob Major Contributor
    5,287
    308
    83
    Nov 4, 2005
    earth
    If the background of your image is white, or at least all the same color, then do Bitmap->Make Transparent... You can mess with the Tolerance setting which represents the deviation from the selected color quantified somehow. If there's holes in your bitmap and you want to cut them as well you can use 'Select Similar' which will select the target color anywhere it's found in the bitmap.
    Once you have made the background transparent, the Effects->Contour Cut will contour the transparency mask and not just the rectangle that is the bitmap.
  6. MCD4x4
    MCD4x4 New Member
    11
    I don't see "Bitmap->Make Transparent" I think the ver I have is 7.0v2
