Cut software for Mimaki CG-130FX plotter
Discussion in 'General Software' started by signmania, Aug 24, 2020.
  1. signmania
    signmania Owner
    93
    16
    8
    May 1, 2010
    Cedar Rapids, Iowa
    Can anyone recommend plotting software for a Mimaki CG-130FX? I don't need any design or print capability. I will import pdf and eps files. I may need to proportionately change the size of the design, and I won't need to contour cut around printed graphics. OS is Windows 10.
    I do have Rasterlink 6plus on the same computer but do not have Illustrator or Coreldraw on it.
  2. unclebun
    unclebun Very Active Member
    We use Sign Wizard and the CutServer from Onyx with ours. It will likely work with most any sign cutting software as long as there's a driver for it.
  3. Antnee
    Antnee Member
    60
    2
    8
    Apr 6, 2015
    San Diego, CA
    We use Flexisign and it works good.
  4. OPENSignsInc.
    OPENSignsInc. Member
    65
    17
    8
    Aug 23, 2015
    Greenville, PA
    Id recommend Signlab10 (by Cadlink), it has a vinyl cutter only version for around $500. We use a couple seats of the print and cut version with our mimaki (C)JV-150-130 printers(/cutter) and our CG-130 FX II plotter. The main thing I like is that it is not a subscription based program, the way most programs are going these days.
    • Like Like x 1
