Hi, My SP300 prints great but the contour cut is off by about a 16th of an inch, not a problem on large graphics but small stuff it really stands out.  I adjusted manually using the test pattern in the print-cut adjust menu but it made no change.  Then under cutting adjust in the calibration menu I set the values to zero as it tells me in the manual, still no change. It has done this for a long time and I would like to get it straightened out if I can. Any ideas?? Thanks
-Michael
ps, this is with laminated prints using the registration marks, it is worse with un-laminated print and cut.
			-Michael
