Cut vinyl for concrete floor.
fine point
Hi All.
We received a request to make large letters for concrete floor (non-permanent). It will be single color each letters and I was thinking about doing Cut vinyls.
So my question is if there are thicker tougher material for cut vinyl. All I found is printing material...
Printed vinyl is never as vibrant as cut vinyl IMO.
Thanks!
FP
Jackpine
Krylon spray or using a foam roller and floor enamal
If it is to be long lasting I would make a stencil from vinyl and
TimToad
As much as it sounds like you'd rather not print the color on rough surface vinyl, I doubt any vinyl including that material will withstand much traffic on it before it starts peeling or degrading.
Even the floor graphic material with a lexan laminate starts showing its age after a while.
Every set of shoes on it acts like a pair of sanding blocks.
