Cut window tint with FC8000
mortil
Hi there. i wounder if there is a chance to cut window tint with my Graphtec FC8000 ?
anyone tried this ?
slipperyfrog
You shouldn't have a problem with that plotter cutting window film. You may need to play with the blades and settings for different films. The most important thing is having a wide range of pressure settings. Higher quality plotters do a better job on films as they can be a pain. Take your time and do plenty of test cuts. We use a 60" DGI for cutting and 25 degree blades. I have it on my list to upgrade to a Graphtec.
mortil
Thanks. Why do you use an 25degree blade ?cause it dont have to cut so deep ?
thanks for the answer anyway :D
