XtremeXccessories
It's happened a few times in the past, but now every file I save that has a CutCountour out line has that outline converted to 100% Magenta. It saves just fine if I use any other spot color (Pantone, Summa Spot, etc) but not with the custom spot. It's not a huge deal since Onyx now warns you if you have a cutter set and no CutContour, but it get's annoying having to change the outline and re-export the file again and again.
Did I change a setting without realizing or do I need to re-install and see if that fixes it?
Edit: Corel X6 by the way.
