Cuttable Paint Mask?
Discussion in 'Vinyl' started by NewSignmaker, May 8, 2011.
  1. NewSignmaker
    NewSignmaker Member
    81
    Sep 28, 2006
    Downs, ks
    I have a customer who has a white car. A good portion of the car will be painted black. On the part that will be painted black he wants me to cut out his company name in vinyl and stick it on the car. The body shop will then paint over it and when finished will remove the vinyl leaving his company name in the original white paint. What would you recommend using for material for this job? A paint mask or a regular vinyl? Thanks!
  2. Custom_Grafx
    Custom_Grafx Very Active Member
    1,637
    2
    That doesn't make sense...
    Won't the body shop be priming the surface before repainting?
    Wouldn't you do what you are saying AFTER it's been painted black?
    Why not just put white vinyl over the new black paint and avoid masking/painting altogether?
    If they really want it painted, why not wait till it's all done, then create the mask, then get them to paint it white?
  3. Jillbeans
    Jillbeans Major Contributor
    14,457
    19
    38
    Dec 24, 2003
    Butler, PA
    While you can use cuttable paint mask (Oramask works pretty well for me as well as for my automotive painter friend) as CG above mentions, won't the vehicle need to be primed, etc. during this process?
    Love....Jill
    PS
    Avoid Avery mask, as it can melt with "hotter" paints, and not sure how well Gerber mask works with automotive paints but it's brittle and really a PITA to work with.
  4. njshorts
    njshorts Active Member
    708
    Mar 15, 2011
    Meadville, PA
    We also use oramask, had great results each time.
  5. Steve G.
    Steve G. Member
    Paint mask from R Tape is Awesome!
  6. NewSignmaker
    NewSignmaker Member
    81
    Sep 28, 2006
    Downs, ks
    I see fellers has the 810, 811, and 813 oramask. Would all of these be good? Are they all cuttable and then can me premasked and installed like regular vinyl?
  7. NewSignmaker
    NewSignmaker Member
    81
    Sep 28, 2006
    Downs, ks
    Are all of the 810, 811, or 813 could for automotive spray applications?
  8. J Hill Designs
    J Hill Designs Major Contributor
    15,549
    17
    I also have no idea why you cant just overlay cut white vinyl? why reinvent the wheel and make it square?
  9. NewSignmaker
    NewSignmaker Member
    81
    Sep 28, 2006
    Downs, ks
    I agree Jill, but its what the customer wants. I'm just not sure which oramask to use.
  10. J Hill Designs
    15,549
    17
    the thing about paint mask is you have to peel it while the paint is wet - they will not be able to prime, scuff, prime, scuff, finish, dry, clear and then still remove the paint mask...theres no way it will work
    edit: well I guess it would come off before the clear, but you get the point
  11. Jillbeans
    14,457
    19
    38
    Dec 24, 2003
    Butler, PA
    I fricking hate painting with a paint mask.
    If you peel too soon it makes a mess.
    If you wait too long the edges chip.
    I am sooo glad I can do it by hand, it's lots faster for me.
    What I do do when I use a mask is lay it down, trace with a pencil, then peel off and handletter. Not really an option with automotive paint tho as the pencil can leave scratches.
