Cutter is skipping.
showcase 66
My cutter just started to skip when it is making a straight or almost straight cut from left to right. All other directions work fine just this one direction. I just ordered a cutting strip for it since I have not changed it out in probably a year and a half but I am not sure if this is the reason.
Smaller letters on this one has become a pain in the a$$ too.
Does anyone think the cutting strip will help this problem or do I need to look at something else.
Thanks.
Mosh
just look at the cutting strip, you can tell if you need a new one. Another thing could be you need a new tool carrier. Sometimes they wear out and the blade hangs up and does not turn fast enough, thuse the skipping.
showcase 66
Cutting strip needs to be replaced. The Blade holder seems to have a lot of play in it and the blade is a little wobbly.
I have another holder and that helped a little but hopefully that and the cutting strip will help alot
Thanks for the idea
thewvsignguy
Sounds like it's the bearing's in the blade holder. We had one doing the same thing, skipping a dragging the blade accross the material. We cleaned the bearing and a drop of oil did the trick, even on a 1/2 worn plotter strip.
