Cutter Making 2 Passes
Discussion in 'General Software' started by Stroker Ace, Aug 5, 2011.
  1. Stroker Ace
    Stroker Ace Member
    44
    I have a Graphtec CE-3000-60 cutter and ProDesign software that I use to make RC car masks for myself and my friends. I believe ProDesign is someone's in house version of Flexi.
    Here's what I did:
    Grabbed a flame from my Mr Clip Art disc, sized it
    and inlined it to make a thin border around the outside
    Here's what happens:
    Blade makes one pass over the inline - so far, so good
    Then it makes 2 passes over the outside border of the flame. During the second pass, it pulls up the edge and makes a mess.
    I have it set to 1 pass in the production manager.
    If I don't inline the flame, it will only make a single pass so it seems like it has something to do with the inline.
    I contacted the vender but he is unable to help. What am I doing wrong? Thank You.
  2. ucmj22
    ucmj22 Very Active Member
    1,509
    1
    The stock clipart might have an extra stroke that you cant see. Some of that stuff is pretty sloppy.
  3. Stroker Ace
    Stroker Ace Member
    44
    Maybe, but before I inline it, the blade only makes one pass.
  4. thewvsignguy
    thewvsignguy Active Member
    657
    Feb 21, 2008
    Grantsville, MD
    Double, no triple check that you have removed any strokes on the image. I know that in flexi sometimes it will add a stroke, for some unknown reason. Even though you might not be able to see the stroke on your screen, the cutter is only doing what you are telling it what to do.
  5. Fitch
    Fitch Member
    369
    1
    Seperate combine, select and delete one of the inlines, then re combine.
    Should fix error.
    Cheers - G
  6. Stroker Ace
    Stroker Ace Member
    44
    That did it Fitch. Thank you.
