cutter to cut tackle twill material
Discussion in 'Miscellaneous Plotters' started by ckeller2, Apr 24, 2005.
  1. ckeller2
    ckeller2 New Member
    3
    will these sign material cutters cut material for embroidery?
  2. High Octane
    High Octane Active Member
    927
    13
    18
    Mar 27, 2005
    Fenton, Michigan
    They will....however I believe it to be somewhat hard on the machine...you should also cut with a 60 degree blade...I suggest applying some of the clear backing to the backside of the material before cutting...makes it a bit more sturdy during the cutting..works pretty well. good luck
  3. flexiezine
    flexiezine Member
    109
    I prefer using the Roland or Graphtec Pro Series cutters whent cutting this type of material. IMHO
