Suggestions Cutting .04 aluminum
bpp
I print and cut a lot of .04 aluminum. My worker sands down all the edges he says he's scared it's sharp and people may cut themselves. Is this necessary? It's extremely time consuming cutting and sanding 200 pieces. All advise appreciated.
ikarasu
What bit are you using? And what CNC?
With the right it the edges should be fine.... Our edges only get jagged or sharp if our bits dull, or if the aluminum isn't being held down right and vibrating.... Then it needs sanding. But generally, no, you don't need to sand aluminum down
GAC05
Quit buggin' me
We use one of these when we rip aluminum blanks with our table saw. Low-tech, low cost, but one or two swipes and the edges are clean.
bpp
I have the colex and use the 530 4mm bit. What about the paint is that normal that it stays on the edge and needs to be wiped off? Like stuck on but comes off by pinching a rag along the edge
James Burke
Get a tool especially for deburring the edges of sheet metal. It'll only take a few seconds to use compared to sand paper. The other style deburring tools are primarily designed for deburring holes, and they usually dig in on the edges of sheet stock.
JB
I have the same issue with the colex and .040. Even with a new bit it is often inconsistent and at the least we need to wipe paint flakes off the edges. I have tried tons of different combos of bits and settings.
gnubler
Deburring tool now on my shopping list. Good for smoothing the edges of ACM also which often gets a sharp edge after cutting.
GAC05
Quit buggin' me
I've been using the single-edged one from the time I was in a friend's glass shop and watched them ripping 10ft long aluminum extrusions on a table saw - then running the deburring tool down the cut edges in single passes.
With the burs gone, I could slide my thumb down the edge like it was a smooth factory edge (no blood).
I didn't know about the double-sided tool, looks like it would be worth a try.
Aaron Hunter
For pre-painted aluminum use a downcut bit and turn your bit rotation to counter clockwise. Should get better edge quality overall.
JstevensonPrints
Printing dreams one day at a time
you shouldn’t ever need a debur off acm when using the proper but, we had Jim from Tritec out not long ago for advanced training and were able to see what a difference but selection makes. I’d reach out to those guys
somcalmetim
If you are cutting straight lines go buy yourself a hand held metal shear for aluminum sheet or ACP...
it makes no dust, cuts faster than a table saw...its like heavy duty 3 bladed scissors that takes a 1/4" potato-fry cut out of middle when it cuts but crimps both edges and doesnt warp material...if you use thicker than 3-4mm material get a Concrete Shear (same thing but hairier)
Like
or
You will never rip acp with table saw again...I just clamp a straight board to acp for guide right now but next bigger ACP job I get am going to rig up a table-saw-ish jig for it...should be able to rig up a mount and some sort of fence easy enough...also cuts large curves if you need them with smooth edges...available in in battery, electric or air powered...
Game changer for ACP that is a great material but wicked sharp if saw cut...even if you are CNCing and this advice doesnt apply specifically...if you work with ACP a metal or concrete shear is a MUST...NO MORE ACP DUST!
Vassago
You always keep the same rotation direction for down cut tools.. Reversing direction would cause rubbing and lifting rather than cutting and pushing the material down.
What are your settings? I prefer a 532 6mm bit, when the cut allows a larger bit. Seems to last much longer and give a cleaner cut.
These settings work best for me:
Spindle Speed - 11,000
Plunge - 13
Feed - 28
Max depth per pass - 0.060
Clockwise cut(climbing)
Assuming the bit is in good shape, I never have to debur or sand the edges. The most finishing I ever have to do is run a knife along the edge to get rid of excess laminate, unless I needed bridges, naturally.
Stacey K
I like making signs
JB
Ordered! Thanks for the link!
Have you tried the settings I suggested?
You should not need to remove any burr from the edge if you are using the right settings.
Try what I suggested with a new bit. I suspect you will have no need for your newly acquired tool.
EDIT: Posted this on another unrelated thread and just realized it can show you what you should expect.
There was absolutely no finishing of those signs(other than the bridges). All edges were clean and smooth.
It seems your and my sound advice has gone unheeded.
Their loss, I suppose.
