Cutting 1" Ultraboard CNC router
Discussion in 'General Signmaking Topics' started by KingsofWraps, Aug 28, 2020.
  1. Morning,
    I haven't been trained yet with the router in detail but I've been trying to do some test cuts and I am having issues. I am trying to cut 1" ultra board on enroute Multicam3000. Can anyone recommend the settings to route in offset section and keypad? Not sure what I'm doing wrong but it does multiple cuts on the same letter about 5-6 and it's only set to 2 in enroute.
    Bit: 1/4" end mill
    Current settings: 1" depth
    Surface: 0"
    Final Depth: 1"
    Passes: 2"
    Max per pass: 0.765"
    Actual pass 0.50"
    Final pass: 0"
    Width of cut: 0"
    Number of steps: 1
    Max step: 0.2250
    Feed rate: 150
    final pass speed: 0
    Plunge rate: 55
    Dwell: 0
    Spindle: 18000
    Conventional
  2. WYLDGFI
    WYLDGFI Merchant Member
    1,296
    149
    63
    Oct 27, 2006
    Linden, NJ
    Do you have multiple copies of the same shape there?
  3. JBurton
    JBurton Signtologist
    1,907
    385
    83
    Sep 28, 2017
    Arkansas
    First of all, if this is the ultrafoam with a metal face, I found my results greatly improved if I cut it with a standard aluminum bit first, just through the aluminum, then came back with the foam bit. It can also be done upside down, with the last cut being the metal bit. I suppose first you really need to wrap your head around enroute properly, before worrying about quality of cut.
    Bit: 1/4" end mill
    Surface: 0"
    Final Depth: 1" (I don't use enroute, it may be very clever, but my router would consider this -1" and if I told it 1", it would run above the material. Seems like this is correct)
    Passes: 2" (Is this an inch unit or a number of passes?)
    Actual pass 0.50"
    Final pass: 0"
    Width of cut: 0"
    Number of steps: 1
    Max step: 0.2250 (this will make it a 5 pass cut I think)
    Feed rate: 150
    final pass speed: 0 (this will cause the machine to stop before the end of the program, or throw an error)
    Plunge rate: 55 (this seems too fast, I tend to plunge at 10, not at issue though)
    Dwell: 0
    Spindle: 18000
    Conventional
  4. Artflop78
    Artflop78 New Member
    1
    Aug 27, 2020
    Los Angeles
    You just need to low your feed rate to 95
  5. LarryB
    LarryB Member
    280
    18
    18
    Dec 3, 2006
    Webster, Texas
    I also have a Multicam 3000. Here are my settings for cutting brushed metal face on foam
    68 speed, 60 plunge, 14000 spindle, climb cut, 2 pass
  6. I am looking for settings for 1" foam with PVC face originally in this thread but if you have 1/2" brushed metal face I'll go ahead and try those.
  7. LarryB
    LarryB Member
    280
    18
    18
    Dec 3, 2006
    Webster, Texas
    Our settings for 1/2" Gatorboard we usually use 1/8" bit. 50 speed, 30 plunge, 400 spindle, 1 pass
