Cutting a 54" roll of laminate into smaller rolls
Discussion in 'General Signmaking Topics' started by Kevspins2, Sep 27, 2020.
  1. Kevspins2
    Kevspins2 New Member
    1
    Sep 1, 2020
    Phoenix
    Hi All, quick question. I have a weird sized laminator (it is 17" wide for small projects).
    I was wanting to see if I can buy a 54" roll and cut it into usable sizes? or have the distributor cut it. I haven't even asked around, came here first to see if anyone has advice.
  2. ikarasu
    ikarasu Very Active Member
    1,900
    597
    113
    Jun 10, 2016
    Port Coquitlam, bc
    Most distributors will cut it for you. Usually it's $5-10 a cut.. Free if you have a good relationship with them / buy it from them.
    You can do it yourself with a chopsaw or bandsaw, but it's not as nice or clean or a cut
  3. victor bogdanov
    victor bogdanov Member
    42
    5
    8
    Aug 29, 2020
    TEXAS
    I cut 60" rolls in half all the time with a compound miter saw, nice clean cuts
  4. karst41
    karst41 Member
    151
    26
    28
    Nov 3, 2010
    Stone Mountain, GA
    What blade do you use and do you slow down the saw speed?
  5. victor bogdanov
    42
    5
    8
    Aug 29, 2020
    TEXAS
    Just a regular wood blade, don't remember the teeth count but its medium teeth size. No different from cutting wood, go slow and let the blade do the cutting. Depending on the saw size you might have to rotate the roll half way through the cut if the diameter is too big for the saw. make sure the roll is taped very good so it does not unwind after/during cutting
  6. Andy D
    Andy D Very Active Member
    2,338
    442
    83
    Oct 20, 2014
    Hattiesburg, MS
    I used to slit my material using a weighted utility knife holder I made, slitting while my printer's take-up
    pulled vinyl through (not printing, the pinch wheels were up) from the supply side & it did a very clean job.
    Edited to add; My weighted utility knife holder had a name, I dubbed him "Sir Slits A-Lot"
  7. JBurton
    JBurton Signtologist
    1,898
    380
    83
    Sep 28, 2017
    Arkansas
    Where were these helpful posts earlier! My distributor quoted $45/roll. Radial arm saw didn't ask nearly as much, but it cut it out of square by about 1/16"
