buzzgraphics
Hey guys, I'm new to the flatbed world and looking at adding a cnc router to finish cut to wood. The units I've been looking at simply read gcode. Coming from the vinyl world, we print corner bomb site marks on a printcut job, the cutter reads the marks (either manually or automatically, depending on your setup) and adjusts its cut code to fit those designated marks. Is there a way to do this on a cnc as well? I understand that theres auto read systems available, but it also seems like i should be able to use the tool to set the four corners of the job and then have it adjust and cut. As it stands it looks like everything is based around the having the substrate set perfectly straight to the platen (or whatever you guys call the cutting platform) and zeroing out the starting point. thats great as long as everything was printed square to begin with, which I don't trust to happen consistently.
anybody worked this out yet? thanks.
