Cutting Dibond
showcase 66
I have to make a 44" circle for a sign and I am using Dibond as the substrate. I was wondering if anyone has used a rotary saw like a rotozip or something like that to cut through the dibond. I was going to test it out on a small piece but the only piece I can find in the shop is a 45"x48" piece which will be perfect for this. I know it cuts really nice and easy with a jigsaw but I dont want to use that for this.
artbot
first if you are cutting a circle you can test your cuts on the corners. those will be the drops. the rotozip will be a disaster. too much variation/chatter. the simple way is use a router. try to bring into the design something in the center to cover up an 1/8" hole. that way you can fashion a circle cutter/compass either out of a 1x4 or a real circle cutter accessory for the tool.
if you are at a loss for tools, most plastic distributors offer circle cutting services.
JR's
the simple way is use a router. that way you can fashion a circle cutter/compass either out of a 1x4 or a real circle cutter accessory for the tool.
:goodpost:
JR
ZsVinylInc
Any time we have to do anything like this we have a local water jet place that cuts it for us. Saves us a lot of time and we can keep moving on other projects.
If you don't have access to the methods mentioned, you could always lay down your pattern, cut it with a jig saw almost up to the line and then sand it with a belt sander to a fine edge. Before all of this technology was around, that's how I did almost everything. Cut-Sand. Wood, metal, plastics, etc.
showcase 66
I feel like an idiot. :doh:
I am not sure exactly why I brought up the rotozip. I have a hand router with a circle attachment. At least you guys didnt make me feel to bad about it.
Thanks for your input.
:thankyou:
amw
Longtime Members
Ask whoever you buy it from...we would pay about $5-$10 for this if we asked for it when ordered. (plus the cost of the sheet ofcourse)
Otherwise a router is the way to go, as said above.
Thanks,
Marsha
