Cutting Direct From CorelDraw on Q100
Discussion in 'Graphtec' started by JustinKaise, Jul 16, 2006.
  1. JustinKaise
    JustinKaise New Member
    12
    The Q100 is basically a 42" Graphtec - the graphtecs have a plugin to cut from coreldraw - anyone got any ideas if I can get the Q100 to cut from CDR? Or is therer a 3rd party who makes various plugin's for these or others? any ideas?????
    THANKS!
  2. OldPaint
    OldPaint Major Contributor
    the graphtecs have a plugin to cut from coreldraw YOU SORTA ANSWERED YOUR OWN QUESTION.....
    i dont thinks its a PLUG-IN as it really a driver....similar to ROLANDS HPGL driver .........
  3. JustinKaise
    12
    response to response........
    I guess it's hard to believe (seeing how they are the same machine) made by same company - that I couldn't just put in the same driver/plug-in, etc???? doesn't that make sense? (of course I'd have to find it first I guess! hehehe
  4. OldPaint
    contact GRAPHTEC......
  5. Howard Keiper
    Howard Keiper Member
    78
    Well, the thing is, although the Q's are made by Graphtec, they're made to order according to the S/W OEM spec...They really aren't Graphtec's anymore. What that means is that they don't speak the GPGL language (as opposed to HPGL), and THAT means they don't respond to Quick-Cut that doesn't speak anything but GPGL.
    hk
  6. TresL
    TresL Very Active Member
    1,010
    Oct 24, 2005
    I am trying get my CE3000 to cut from ILL or Corel and have major issues.
    My Cutting Master Cd was lost in a recent move and Graphtec wants to charge $200 for a replacement CD.
    Which driver/plug-in are you using to cut with?
  7. Jackpine
    Jackpine Major Contributor
    cutting from Corel
    Contact SSK support. They can figure it out.
  8. mpa1971
    mpa1971 New Member
    18
    Using Corel w/ Q-Series
    I asked one of my senior techs to look into this matter for you all. Please see his comments below. Hope this helps!
    Kind Regards,
    Mike Akard
    SIGNWarehouse.com
    Technical Services Manager
    Ok, cut using Corel Draw 12 (also works for Adobe Illustrator)
    Customer will have to first install the cutter on USB using the USB drivers on the Q-Series CD.
    After creating the design in Corel, they need to remove the fills, and set it to hairline strokes.
    Then they just go to Print and select the Q100 as the printer.
    They need to make sure that what they see on the screen is what will cut.
    Any overlapping lines or crossing lines will cut unless they are welded together.
    Updated Information:
    In order to cut using the USB driver, the cutter has to be set to GP-GL Mode.
    On the Q100: (page 169 of 176 in the Q-Series Manual)
    Without any media in the cutter, turn the cutter on.
    From the Load Media Screen, press F4 for Initial Menu.
    Press F4 for Command
    Press F3 for GP-GL
    Press Enter to save your setting.
    Power the cutter off and back on.
    Load media, then follow the previous procedure to cut from Corel.
    SW - Tech Support
  9. TresL
    1,010
    Oct 24, 2005
    Worked on my Graphtec...
    The menu is a little different, but, I think the main issue was the reboot of the machine after setting GP-GL....
    Thanks.....
  10. n20capri
    n20capri Member
    131
    Yes I just had a similiar problem with my CE3000-60 and Illustrator. The default driver is the HP one...have to switch it to the Graphtec driver...worked for me...
