Cutting errant "v" notch
jimi
My FC-7000 will sporadically cut a small v-notch along the edge of vinyl letters. After making adjustments my repeated cut group is 4 words of cursive letters. The imperfections always occur in the same place but not necessarily in the same letters. It will cut a v-notch in the same place along the letter "a" in the word Family but not at all in "a" from word Operated. I've changed to a new blade, and increased the blade cut angle.
Any help appreciated!
Stealth Ryder
Cutter Issues
Bad/worn out blade holder...
Grooves in the cutting strip...
Bad Blade...
One or more of these three things cause what you have described
blueben
How long of a cable do you have running from your computer to the cutter. I had the same problem with my Roland GX24. When I called in, the tech asked me that question. At the time, I had a 24' usb cable running to it. Told me to shorten it to no more than a 10' cable to help the communication to the cutter. Re arranged the layout of my cut area and have not had a problem in 9 months.
Something to think about anyways.
