Cutting From CorelX3 to a Graphtec
Discussion in 'Graphtec' started by Gatelen, Jan 5, 2007.
  1. Gatelen
    Gatelen New Member
    1
    I've looked everywhere for a way on how to do this but I keep getting a "Error" on the plotter everytime I try. Is it possible to cut directly from CorelX3 to a Graphtec FC2100-120 on a LPT1 port?
  2. rcook99
    rcook99 Very Active Member
    2,135
    3
    38
    May 25, 2006
    NE
    I use a seperate program to cut from Corel X-3 called Sign Tools 3 and there is also one call I believe Cocut. Other than that I don't know of any other way. There is a guy on another board I go on who goes by the screen name FLUID and I will say If there is a way he would know. You can also try this board www.unleash.com you may find some help there.
  3. 2NinerNiner2
    2NinerNiner2 Very Active Member
    1,122
    Mar 21, 2006
    Calgary, AB
    Not sure about the Graphtec, but I used to do this all the time with my Roland CAMM1; cut directly from Corel (using the Roland-supplied driver), and X3 was the latest version I did this successfully with. On the Roland models, I never had any luck using the LPT (parallel) connection and always (since 1988) used the COM (serial) connection, but you ABSOLUTELY require either the correct Roland cable (XYRS-64) or a null-modem cable; the pin-out on a 'regular' serial cable isn't correct. This sounds as though this could be your situation now.
    Cheers!
    Lyle
    PS... just noticed this is your first post, so bonjour de Montréal and S101 :)
  4. signage
    signage Major Contributor
    9,312
    41
    48
    Oct 5, 2005
    Penn
    If you have a windows driver or if it accepts hpgl I am pretty sure it can be done. everything has to be set up right you will not get any preview.
