Cutting in Reverse
Strikenmike
Strikenmike
Greetings. When I try to cut using Signl10 it cuts in reverse as if I had selected the mirror cut option. Cuts fine with a different software package, but I need to learn this Signlab software.
I need help figuring this out. It has worked in the past. CADlink wants $'s to resolve the issue.
Hoping someone online might help me resolve the problem. Thanks.
2B
worked in the past? what has changed, new computer, update, etc...
not familiar with the program, just random thoughts
netsol
can't you just put the checkmark in and retore to normal?
did you reboot? typically, ifa reboot is too much trouble,we restart explorer
(task manager>processes>explorer>end task>file>new task>run>explorer>ok
this works for instance, when adobe files only print in b&w
OPENSignsInc.
What plotter are you using?
Is it "mirrored" front to back or side to side?
Cut>Plotting Defaults is mirror checked?
Are you cutting straight to port from signlab or using production spooler/VPM?
Are you cutting plain vinyl or trying to contour cut a print?
Are you running the latest drivers for your cutter?
What other program were you using?
Z SIGNS
Can't really help you but....in the mean time till you get it sorted out just send your plots over mirrored
