bbankston
I've had the Summa D120 Summacut series plotter for about a year and a half now. Prior to the Summa we had a Gerber sprocket fed plotter that just wasn't cutting right anymore. I purchased the Summa thinking that it could cut everything from text, logos and lines perfectly. Well I found, to my dismay, that it will not cut vertical lines accurately at all. Does anyone know of a way to get it to cut accurately on a traction fed plotter? Does anyone have a sprocket feed plotter in the Houston area that I can rely on for cutting vertical lines for me when I need to outsource this work?
Right now I need to cut a "blind glass" job. Blind glass is created by cutting 1/4 inch wide by 12 inch tall lines next to 3/8 inch wide lines at 12 inches tall. And then you center another piece of vinyl, cut the same way, on the back. It's called "blind glass" because you can't see looking dead on at the glass but you can see through it at an angle. The 3/8 inch lines are sandblasted while the 1/4 inch line is left clear
Many thanks,
Brandon
Many thanks,
Brandon
