bbankston
Un-spools everything it needs before it starts to cut anything,
or as needed, every so often, during the cut job?
Just trying to trouble shoot with you.
I've tried that too, Stanton. Didn't work.
I've even made sure that my artwork is drawn so that the plotter cuts as efficiently as possible. (e.g. 1st line cuts up - 2nd line cuts down, etc.).
If I cut the whole 48 or even 36 inches it'll eventually bunch up or crease on me. I have to hover around the plotter and knock those creases out so it doesn't bunch up.
...could the knife be cutting into the liner
causing the liner to "accordion fold" and fail?
Negative, ghost rider. I make sure that the backing is not touched with the blade.
What happens when you rotate it 90º ?
I've actually had a Summa rep. come out and he says that I can't do what I want.
YesAny one else think this is unacceptable?
