blacknbart
I got this message when I was trying to send my artwork from illustrator to Cutting Master 2. My graphics guy set it up correctly, but once it loads from Illustrator it shows this error message "Contour cutting is not supported for multi page design". My Artwork displays 90 degrees in the Countered Clock wise position. Please look at my attached files for a better understanding. I was able to click on the position button to turn the artwork to it's correct position, but noticed the "Use Reg marks" box was unchecked. After checking the box I got the same error message "Contour cutting is not supported for multi page design". My artwork also went back to the wrong cutting position again. I did double checked the Reg marks on my file in Illustrator to make sure they were set at Horizontal rather than Vertical. What is going on here? Thanks in advance for the read thru and for any possible solutions. I will be checking this thread constantly so as to get back to your questions. Thanks for the support.
