Cutting Master 4 and VinylExpress Q160 ?
Discussion in 'Miscellaneous Plotters' started by dypinc, Sep 9, 2019.
  1. dypinc
    dypinc Very Active Member
    1,654
    114
    63
    Mar 9, 2011
    CCPUSA
    I an effort to move on to IL Version 23 and OS 10.14 I have been testing CM4 with it. Everything seems to work fine with the Q160 expect when reading targets for cutting. Hitting the print button in CM4 the plotter goes all the way to the lower right of the vinyl. If I have disable going to the Ok screen check then it will try to find the first target at that point. If I have the OK screen come up I can then move the head back to the start position and then ok it and it will read the targets just fine and continue cutting. This is ok for small jobs but for big jobs where the vinyl is laid out on the table for weeding while it is cutting that won't work. I have not tried the #2 load option yet to see what that does.
    Anybody tried this combination and found a setting that might make it behave like CM2 and not move to the lower right when hitting the print button?
  2. dypinc
    1,654
    114
    63
    Mar 9, 2011
    CCPUSA
    Bump to top.
    Anybody?
  3. dypinc
    1,654
    114
    63
    Mar 9, 2011
    CCPUSA
    Anybody find a solution for this? Does it do this with the FC8000 cutters?
