Need Help Cutting multiple sheets on the flatbed cutter
MGB_LE
We are contour cutting about 200 duplex round cardstock cards. We print them 6up on our digital color cutsheet press on 12x18" sheets. We contour cut them a sheet at a time. There must be a way to keep the flatbed cutter gantry near the work while we swap out sheets? Right now it moves alllll the way to the back of the table between sheets. It's a silly waste of time and motion.
FireSprint.com
Wholesale Signs, Stickers, Banners-Free Shipping
On our zunds this is called the park position and it can be set at the beginning of each job. This is where the gantry will go when the job is done. Maybe your machine has something similar?
S2S
when you select "output to device"...there is a park position that will allow you to do this...both x and y
MGB_LE
Thanks everyone, I will check that out on WinCNC (or OptiScout, I forget which, since I'm not the operator.)
S2S
in the OptiScout program...output to device...window opens for you to set this info...park position X and Y...
Go to WinCNC...move your beam where you would like it to park....enter the X/Y coordinates from WinCNC into OptiScout.
  • Agree
Reactions: 1 user
MGB_LE
Worked like a charm. sorry it took a while to report back. I don't like when I see that on other forums. This'll save us lots of time.
S2S
Wonderful...glad it work and hope that it helps out with your workflow!
