i never use the barcodes. just check the first 3 digits of the number pull it up in postershop cut and hit go.
also i would make sure your reg marks for cutting are set to dark. it will find them easier
When cutting reflective we typically have the white squares that we put around the graphtech marks, but since you're reading barcodes, that wouldn't work. So maybe try blocking out some of the overhead light while it's scanning. Ex. During a certain part of the day where the sun breaks through the window just right and touches right where my marks typically are when the material is in the machine. The process fails every time it tries to read that mark. So we patched the hole, and no more failures.
I recently got an HP Latex print and cut package. today I printed decals on reflective material. When I took the print over the cutter it was not able to locate the barcode. Anyone know a trick to getting the cutter to read the barcode on the reflective material?
Do you have the option of using a manual registration? I know that with Flexi you can choose to use cross hairs or 'bomb site' and manually set up the registration marks. We do this all the time have don't have any issues.
No, the HP Print & Cut System prints a barcode to read and pull the correct graphics file from Flexi and position/align the substrate. There is no option for manual registration that I can find. BTW, the plotter is actually a Summa which HP has rebranded as an HP.
