Cutting stickers out
midnightmadman
Whats the best way to cut completely through the vinyl and the backing to make shaped stickers?
I don;t want to damage the plastic strip or the blade.
Travis Stanley
Place a backing on some scrap vinyl do a practice cut and then adjust the depth as needed. small increments to get the desired cuts
Flame
Not happening. I've put countless hours into figuring it out, as I make a lot of small decals for customers....and simply put, this WILL put more wear and tear on your blade, as opposed to just cutting vinyl.
Are you printing & cutting via registration? I do this daily (printing and cutting the decal, then cutting the backing paper about .13" away from the edge of the vinyl)
Shoot me a PM and i'll tell you how I do it.
CheapVehicleWrap
Yeah me too! :). Finally gave up on wanting perf cut. I have a method I cut on a 10 foot cutter bar. I can cut hundreds in minutes perfectly square.
natedawg9640
we do it. though it's sort of cumbersome.
we only do it every once it a while, so we just put premask on the back side of the liner and then adjust the blade depth to cut through the vinyl and the liner, but not through the premask. the mask acts as the carrying liner so when it's removed, the decals just fall out.
Williams Signs
Got graphtec and download cutting master software. The Q100 is the same machine as a FC7000. Then Make sure your cutter is connected through USB. Next got to you tube and do a search on cutting stickers. There is a video out there that shows you exactly how to do it.
