Decal Cut Question For 2.5
Discussion in 'Gerber' started by butsie, Apr 7, 2006.
  1. butsie
    butsie Member
    47
    I have a vector shape logo that I want to put a decal cut around but the side of the vector shape the decal cut line falls inside the vector shape. Is there a way to add some more area around the vector shape using the decal cut option?
    Thanks, Mary
  2. Tony Teveris
    Tony Teveris Active Member
    Mary, there is no way through DecalCut to do this. If possible could you send me the original PLT file w/o the decal. I'd like to figure out "why" it's doing this.
  3. butsie
    butsie Member
    47
    I will send it today Tony and thanks!!
    Mary
  4. Fred Weiss
    Fred Weiss Merchant Member
    20,571
    426
    83
    Sep 11, 2003
    Olympia, WA
    Mary is this the same file I processed for you?
  5. butsie
    butsie Member
    47
    No it is not Fred, but thanks for asking! I did have trouble with the file you sent me though. I sent you an email, let me know if you received it or not. You said that there was two attachments but ther was only one and it did not have a plt extension.
    Mary
  6. Fred Weiss
    20,571
    426
    83
    Sep 11, 2003
    Olympia, WA
    I have placed the three files in a zip file and emailed it again to you. I think there may have been a file size issue with your ISP. I never got an email from you though, so I was not aware you had a problem.
  7. butsie
    butsie Member
    47
    Thank you so very much - I received the zip file and I'm in the process of checking them out. I will get back to you and let you know how I make out with the files. I have soooooooo much to learn, I really appreciate all your work into this graphic for me.
    Mary
