Need Help Deep contours on wraps
Discussion in 'Tips & Tricks' started by bayviewsignworks, Aug 7, 2020.
  1. We're using 3m ij180cv3-10 gloss with 3M 8518 gloss laminate. Especially with the new vans and the rear side panel contours we're getting lifting after we've delivered the job. We use the 3M liquid (twice) before getting as close as we can before using heat. Using hand/finger/squeegee or a 3M contour roller we still get some lifting. We've decided to cut the job from now on after it's done.
    Spectrum internet/cable trucks I've seen have a perfectly cut area right on the horizon edge that could not be done by hand-how did they do that??
    I'm wondering if they put down a knifeless tape; but with two wires 1/8th inch apart? I haven't seen that product.
    Anyone have any other suggestions?
  2. MikePro
    MikePro Major Contributor
    4,964
    233
    63
    Feb 3, 2010
    Racine, WI
    pics to confirm, but most likely used knifeless tape.
    it comes in 1/8" sizes, so in theory you could run a line of tape and then run a matching line alongside it.
    for me, i start with the deep grooves, unstretched...just tucked. once you make the turn, you can stretch a bit to get the bacon-collar back to a straight light and then continue wrapping outward.
    • Like Like x 1
  3. SIGNSOURCEAMERICA.COM
    SIGNSOURCEAMERICA.COM New Member
    1
    Aug 6, 2020
    lake worth
    The www.Wrapinstitute.com is an awesome resource for ANY wrap related issue.
  4. signman315
    signman315 Signmaker
    326
    96
    28
    Oct 5, 2015
    Leonardsville, NY
    Tuck everything you can and heat it to establish a clean line again after the channel and if you have to stretch into a channel do it in a way that you are "pushing" the vinyl into the channel giving it as much material as possible. Prime the channels with primer 94 and if still getting issues relief cut it. But if tucked/stretched properly and primed it shouldn't lift.
  5. Jester1167
    Jester1167 Very Active Member
    Switch to Avery and make sure you leave an 8" gap. Focus the heat (which is where the stretch will come from) away from the indentation you are trying to tuck it into.
    Avery can conform without failure with this method. With 3M, the stars have to align for it to work. and if it does the overlap seams will still probably fail in a year or so. If you have to use 3M, cut it with knifeless, and drop it in.
  6. Bubba06
    Bubba06 Just Somebody
    418
    122
    43
    Feb 13, 2005
    Manning SC
    If the problem you are describing is what I think it is, this may help.
    Dont heat and stretch on the crease. Stretching is what causes you to lose adhesion.
    You want to heat and stretch where you can spread it over a bigger area, not that small crease.
      File size:
      223.6 KB
      68
    • Like Like x 2
  7. Thanks for replies. Will ry all - including Avery, which one?
  8. jfiscus
    jfiscus Map Wraster
    3,190
    239
    63
    Apr 2, 2009
    Cincinnati, OH
    Don't switch vinyls, just get some more training. I know personally I can't do what the better installers here can do and I gladly admit it.
    The cuts you're talking about are just made by good/steady installers, so are the wraps that don't lift out of the deeper recesses.
    Spend the money and get to the 3M wrap certification class, you'll learn a lot there about how/where/why of working the vinyl. In the end some installers can do both without any issue and others can't.
    • Like Like x 1
    • Agree Agree x 1
  9. Bly
    Bly Very Active Member
    3,042
    365
    83
    Mar 9, 2004
    Sydney
    1105
  10. Thanks all. We'll probably do a mix of all of these. We def ned more training but i think with a few helpful videos we'll get by.
  11. Behrmon
    Behrmon Pr. Bear-Mon
    347
    28
    28
    Apr 9, 2015
    RI
    Wrap institute for training, maybe try 3M 480 (it’s better!), Post Heat Post Heat, Post Heat. :)
  12. XtremeXccessories
    XtremeXccessories Member
    182
    25
    28
    May 18, 2012
    Layton, UT
    Like others have said, heat the flat area and work, don't stretch, into the recess. And as Behrmon said, post heat, post heat, post heat. To the correct temperature, use an infrared thermometer. Also keep in mind that overlaps need to be post heated to a slightly higher temperature than normal, I think 220° is what Avery recommends.
  13. rydods
    rydods Member
    315
    37
    28
    Feb 15, 2007
    Wisconsin
    With Avery 1105 make sure to use 1460 overlam. It's better for these deep recessed areas.
Similar Threads - Deep contours wraps
  1. jesselopez5000
    6
    498
