Deleted jobs in pm
Discussion in 'Flexi' started by insigniagraphics, Mar 18, 2013.
  1. insigniagraphics
    insigniagraphics New Member
    24
    Mar 7, 2012
    valrico, fl
    Is there any way to recover a newly deleted job from the production manager? i have a printed piece to which the accompanying cut-file has been deleted this morning! Any ideas???
    Using Flexisign Pro 8.6
  2. SightLine
    SightLine Very Active Member
    "If" you still have it open and Flexi and/or hopefully saved it in Flexi then just resend the entire job. If anything has been changed or modified though you will need to reset it to be exactly like it was. Make sure your printer is offline first too then just abort the print job in Production Manager and use the new cut file that is waiting. Done this more than once.... :wink:
    I wish Production Manager would PROMPT with an "are your sure" or something before deleting jobs. Too easy to accidentally hit the delete key and realize the job is gone for good.
  3. mopar691
    mopar691 Member
    390
    Sep 15, 2010
    Like Sight said but just send contour, not print job. I believe in the last tab when outputting there is the option.
