DELL VOSTRO 1500 notebook partition.....
Discussion in 'Computer Hardware' started by Shovelhead, Feb 20, 2008.
  1. Shovelhead
    Shovelhead Major Contributor
    10,882
    16
    I'm very pleased with Acronis Disc Director....I tried to partion the HD
    and saw that I have a hidden FAT32 partition allocated as a "memdump"...
    after I split the main C: drive I got an error....suspect it's from the existing partion....what is that preinstalled "memdump"?
    :thankyou:
  2. TonyHoles
    TonyHoles Active Member
    580
    it probably has nothing to do with the memdump partition...what is the error you are getting???
  3. Shovelhead
    10,882
    16
  4. signage
    signage Major Contributor
    10,720
    299
    83
    Oct 5, 2005
    Penn
    Most of the time those hidden partitions are for the recovery files shipped with computers. What you may have to do is reformatt the hard drive and reinstall.
  5. TonyHoles
    580
    I would try to do a "repair" on each of the OS partitions before reformatting completely so you don't loss anything.
    Try running a repair and hopefully it will fix whatever is causing the error.
    To run a repair it's similar to reformatting but just choose the repair a partition option. I would run it on both OS's
  6. Shovelhead
    10,882
    16
    Do I really need the crap on that small partition???
    I'll upload a screen shot later.
  7. TonyHoles
    580
    Whenever I reformat I do away with that partition space. Others would probably say keep it but I don't.
  8. John M
    John M Member
    66
    As long as Dell ships a real XP disk you can delete the partition if you feel like it. If they use a recovery disk that relies on that partition you'll be dead in the water if you ever need to reinstall.
    Then again, reinstalls usually happen after the hard drive dies and that means that partition would be useless anyway.
Similar Threads - DELL VOSTRO 1500
  1. Bobby H
    60
    4,173
