Design question
Does someone know of a video to help me design a effect like this. I'm wanting to recreate the shine effect starburst. Could you also just tell me what it is called. The problem is my designer uses Flexi and I believe to make this look right he will probably need illustrator and/or photoshop. Any help is greatly appreciated.
myront
Dammit, make it faster!!
Very easy to do in CorelDRAW. Once made you can add it as a brush object whereby allowing to click and drop in as needed.
Joe House
Sign Equipment Technician
I'm not at my desk right now, but it would be easy to do the same in Flexi. It mostly depends on what software you know well. Flex, AI, Corel for the most part all can do the same things, it mostly boils down to what you use most and what you've learned.
Sent from my SM-G955U using Tapatalk
AKwrapguy
No so easy in Flexi due to limited gradient functions, but you can make it in Illustrator or photoshop and save as a .psd or .png and import into flexi pretty easily. In flexi you would basically make the shape you want and create a block shadow and than fine tune it.
