Christian @ 2CT Media
No problems, just cost involved.
Not squeamish at all, what gave you that impression? I just stated that those prices didn't include licensing which is a variable based on each Profile needed.
I'm wondering about any human administration costs of time for such a setup including the admin of apps. Minimal so much as it's not even worth the trouble to calculate, or minutes a day, week, month, etc.?So meeting went well, they are going to spec out a a few options but we are sub $65,000 for everything we discussed as of now.
They recommend Hyper-V to start since we are under 25 concurrent users. But a 64 core 128 thread server with 1tb memory and 10tb of nvme is around $58,000, 10g thin clients are $880/ea and then there is licensing
$300/mo for remote maintenance, monitoring, updating and tech support. We do all hardware / on site physical networking.I'm wondering about any human administration costs of time for such a setup including the admin of apps. Minimal so much as it's not even worth the trouble to calculate, or minutes a day, week, month, etc.?
Its still very much worth it in my mind. Especially considering auto-allocation of resources based on demand. So if this case if a designer is consuming their allocated resources based on a job demand, the system will automatically provision more resources to help them power through projects.
Just as a perspective...Its still very much worth it in my mind. Especially considering auto-allocation of resources based on demand. So if this case if a designer is consuming their allocated resources based on a job demand, the system will automatically provision more resources to help them power through projects.
How so, exactly, in your experience?That is a harder solution to manage
An operator may use one workstation for design, say and another for RIP and even another for work admin / correspondence, etc., all simultaneously. It has been common for many years in my experience.yet alone a person can only physically work at one station at a time.
I used the term "disk" generically.Disks are a thing of the past,
Do you know for certain that apps such as Photoshop will work only in RAM without hitting a disk in normal operation? A RIP? Any app?But compute scale and ram scale is limited on non server based architecture.
Since I don't know what this is, it's a good time for me to wish you good luck on your quest. Truly.Moving to HLE Workstation class hardware is so close to server grade it's lost value.
Yes there is the point of diminished returns, if you can only scale 1 performance aspect. We would have Core, RAM, and File IO scaleable. Which would help Photoshop (No cap in 2019+), Illustrator, and Onyx 19 (uses load balancing beyond your singular rip cores).
ColorCrest HLE is High Level Enthusiast ie Workstation Class hardware without going full server grade (Intel 10980xe, AMD Threadripper 3, Intel Xeon Ex series, etc)
Software is always the problem, and those problems will rear it's ugly head on a individual system as well.I cannot imagine that there still isn't going to be software bottlenecks in there. This is definitely not the typical use case for their customers, so for them to have their software code based optimized for such deployment, I can't see it. Typically those that have sophisticated systems like this typically have custom pipelines that also help with the main system.
This is where I am at for my main office/designing rig. Couldn't be happier with it.
We have talked about building all of our future machines as a server class workstation, but cost goes up dramatically which lead my thoughts down this path.
