Ok. I knew this would stir up a lot.
answering questions in no particular order........................and I will probably forget a few but here are some answers
The Machine is a Roland Soljet pro III 54" And yes I am aware that solvent inks need ventilation.
Purchased a laminator from the same place at the same time as the machine. I am very aware of the need to laminate on certain things.
The ripp software will be versaworks
The place I purcahased the machine stated just like a lot of you people did that software is a matter of preference and they didnt want to try and sway me toward anything in particular.
No design background and we are fully aware this comes with a HUGE learning curve. Will be getting training on whatever we decide.
We will be designing most everything we do. We are Mainly targeting a Niche market.
Most everything will be wraps like on trailers. A very few vehicles and some sign work. - 90% of the work will be for outdoors
What did I miss?
No, no problem at all, telling us the whole story, is there ?? Unless stirring the pot was your intention , many of my questions were based upon your neglect of giving us enough information. See, so many people want answers and by not giving a full story, your answers sometimes could be wrong. Helping us to help you is just a natural process. It's just like getting a job and requesting a deposit. It helps you finance their job, instead of the burden being on you, alone.
However, you seem like you're annoyed by this, so suffice it to say......... good luck. I won't bother you, unless something good comes along.![]()
My wife always tells me not to judge peoples emotion from a text message, email or something read on the internet because you cant exactly tell what emotions are in the writing.
It did not annoy me to answer the questions. I apologize if it came of that way but that was not the intention. Also I was not purposely stirring the pot. After making the post I read through many many posts on here and other forums and realized that its a very opinionated subject and it may spark some controversy.
There was no reasoning behind leaving information out of the first post besides I guess I didn't think it was pertinent. Remember I did say I was new to all this. I wrote the post to gain the knowledge of what everyone else thinks is the best software to use and the easiest. I was unaware of the amounts of options. I was trying to save myself a few dollars since software is pretty pricey. Again, I am sorry if it came off wrong to you Gino and anyone else.
Not all of us can wake up a gifted soybean farmer, like Mosh.Mosh,
You must of been one of those gifted people that just woke up and could design. You obviously had to learn in the beginning like everyone else. Thanks for the intelligent input.
And for the record I did not really purposely intend to put the cart before the horse. I have been researching equipment for quite some time and happen to come across a deal that was too good to refuse so I purchased it. The original plan was to get the software and work with it to learn and then buy the equipment. Not everything in life happens how we want it too and sometimes we have to adjust...........
Most "professionals" use Adobe CC
"Professionals":ROFLMAO:
If you expect to do "output bureau" work = working on files from professional designers - go with Adobe CC - that way you will be able to open everything. I would get the $50/month package...Acrobat Professional is your friend - Photoshop is great - Illustrator is the standard for vector work.
If you expect to do "output bureau" work...you need Adobe CC. Really?!
If you expect to get files from companies that use professional designers - same as above. Otherwise you will run into problems chasing files that need to be down-saved. Adobe is allowing less of that as time goes on.
If you expect to get files...that use professional designers.... Apparently you work with that rare designer that can actually package files correctly for output, or not send RGB files for offset work.
If you are designing for yourself - choose what you have the best support with. Many use Corel - I have not used it in years.
If you expect to do typical sign shop vinyl cutting - you'll need a sign package. I have used many - and I find Gerber has the best - but that is not saying much compared to Corel and Illustrator. The issue is - cutting easily is hard from the non-sign packages without some plugin.
In all the sign shops I worked in - it usually is more profitable to work with customers who provide professional files. YMMV
My point of this thread was to find out if there was a better or easier version to learn. Did not know if one or the other offered better options that only a experienced designer would know like all of you. That's why I asked. I know the software wont make you a better sign or graphic. I fully understand that. My first impression was to use illustrator and flexi. Didn't want to later have someone say it was a bad choice because of such and such.
For those of you that answered with a legit answer I sincerely thank you.
Adobe website sucks in my opinion. I cant see anything regarding "CS6 suite". Everything I see is choose your programs. Do they have a complete package for the suite and I am missing it? Cause there are a few there that I know I dont think I need. Maybe I am looking in the wrong place on the site.
