Shift Designs
anyone know what would cause this. i am using 8.1. I have lightened artwork, but they still print back dark. They are pdf's out of illustrator.
Screen cap and print a small test print of that in a new file.
That will tell you if it's the file.
If it is the file I'd work on exporting it til I found a acceptable answer.
I have had problems with gradients taking forever or locking up when sent. Then a tif copy gigantically larger in size zoom through.
Have you printed other thing fine? Sounds like your darker/lighter could be a printer issue.
It's been my experience that flexi and illustrator don't always like each other and flexi won't behave how you want it to with these files. Usually it's ai files that a "graphic designer" designed and it's some moron that doesn't know what the hell they are doing. You may have to have the "designer" turn the art into a jpg to print correctly.
Mark galoob
