dialog box does not appear-Illy CS2
katee123
I have a strange problem.
When I attempt to save an item in illy CS2 the dialog box does not appear.
Its driving me mad because i can't save anything. Export does not open either. The screen just kind of flashes like it opened but I can't see it....please help.
beermonster
trash illy prefs file and restart
dont cave in straight away like most folks and start re-installing stuff - it's not often needed
by the way - what system - mac/pc? OS version etc
:rock-n-roll:
beermonster
ok i'm mac based so shooting in the dark - sorry
i'm not convinced that illy cs2 is recommended for vista - (is anything????) - maybe check that out. CS2 has been out a while, maybe make sure you have all updates installed too.
Tony Teveris
Did it ever work under Vista? If and I'm not sure but if Adobe was using standard Microsoft Open/Save dialogdox code it changed in Vista. But I would think this is the case only if it never worked on Vista for you.
I just found a system here with CS2 on it but it's a Win 7 system. I see that Illy has two Open dialog styles, standard and Adobe.
Service Sign Co
There's a little AI in the left top corner that says restore when you click it. I have no idea what it does,but it probably can't hurt anything.
Tony Teveris
Katee, I see you tried the Adobe forums. Sometimes they help but are not watched much by actual Adobe engineers which is a shame.
