die cutting and half cutting with cg-160fx
Airborneltp
So I think I came up with a solution on fixing my messed up cuts. But I don't know how to set it up. See attached.... How would I do this. I have my half cut working so I can punch out stickers, but how do I make 2 separate cuts on the same sticker?
vital-signs-usa
Better late than never?
This is possible. You can put two contour cuts on it that are different colors. Then you can set your production manager to run each color on a different setting or to pause between colors and you can manually change the settings on the plotter between colors.
