Theres 2 ways. You can have it in the third holder using the same blade and kiss cut and then perf cut without having to move blades... OR you can set it up to run condition 1 which is a kiss cut, then once all of condition one is done... run 8, at which point itll ask you to change the blade position and then auto start cutting without having to read again. You can get crafty and kiss cut all around the design and leave the marks... then weed and then perf cut if you want them pre weeded. I've been just perf cutting right to the edge these days though... personally I find it harder to peel the stickers off, but customers seem to like it that way.
You don't need a special blade or holder for perf cutting. I use a CB09 holder and CB09 blade for perf cutting. You just need to put it in the "third" slot and tell the condition it's in the third slot and you're good to go! You have to extend the blade more... so if you only have one holder it gets annoying constantly having to adjust it in and out, but thats the only downside.
I recommend buying this...
https://www.amazon.com/Graphtec-Hol...?dchild=1&keywords=cb09&qid=1618359480&sr=8-5
For $16 you get a holder and 15 blades... The blades arent bad, they dull pretty quick... The holder is great for perf cutting, but theres a lot of play in it... so I wouldnt use it for small letters / kiss cutting. But it makes a great dedicated perf cutting holder! Plus you get 3 diff types of blades to play around with and find which works best for you perf cut wise. I use the 60 degree ultra sharp ones. (Be careful though...as some chinese blades call the sharp ones 60, some call it 30... so if you do ever buy them, look at the photo and not the degree size! Even if you dont perf cut much, or intend to... for $15 its not bad to play around with. It can come in useful for other jobs as well
