Digital Print numbers for personal aircraft?
Discussion in 'Vehicle Graphics' started by Reveal1, Mar 25, 2020.
  1. Reveal1
    Reveal1 Active Member
    676
    227
    43
    Nov 7, 2010
    Cape Girardeau, MO
    Found several older threads on this regarding wraps of commercial aircraft (a whole different ballgame) , and cut vinyl for smaller aircraft, but not much on digital print. Customer has personal aircraft wanting digital print numbers. Anyone here have experience with this? Does it require FAA approval as with wraps? Special materials? Was thinking cast wrap material like Arlon 6100 that we use on trailers.
  2. bannertime
    bannertime Very Active Member
    2,160
    505
    113
    Sep 8, 2016
    No
    Honestly, I'd ask the customer to verify and provide this information.
  3. unclebun
    unclebun Very Active Member
    The rules are here: https://www.govinfo.gov/content/pkg.../CFR-2017-title14-vol1-part45.xml#seqnum45.21
    This is a clarification document which expands on it, and explains that you cannot use removable tape except under certain circumstances of temporary lettering (which is covered in the rule linked above also) https://www.faa.gov/documentlibrary/media/advisory_circular/ac 45-2d.pdf
    The pdf does say you can use decals in the same paragraph that says you cannot use removable tape. However, the point of that paragraph seems to be that the marking has to be permanent, with removal being difficult.
    • Informative Informative x 1
  4. rjssigns
    rjssigns Major Contributor
    5,208
    549
    113
    Jun 4, 2007
    Home Office
    I was told if it's a homebuilt darn near anything goes. Interesting chat with a husband/wife team building a plane. They wanted to talk about a wrap. Told them no way I was touching it because of airframe regs. Found out they talked to others that had built the exact planes and wrapped them.(photos were gorgeous) Those people actually talked to the FAA beforehand to get the skinny. Homebuilt is a completely different animal in the eyes of the FAA. Maybe something has changed since I talked to them? Always best to check.
    • Like Like x 1
  5. unclebun
    Just wondering why they would want digitally printed numbers. They are supposed to be solid color and shadows and outlines are only allowed when necessary for readability.
  6. Reveal1
    676
    227
    43
    Nov 7, 2010
    Cape Girardeau, MO
    Thanks for bringing that up - I'll ask. Hope things are going well over there in the central part of the state.
  7. Reveal1
    676
    227
    43
    Nov 7, 2010
    Cape Girardeau, MO
    Thanks all - we decided to use Cast cut vinyl instead. Appreciate the feedback.
