When using a metallic vinyl which is directional, where the hood is wider than the material width, which direction do you run the vinyl? Hood on jeep is 64" at widest point' plus it's rounded to the side panels. If the direction of the vinyl on the sides runs horizontal, do you run the direction on the hood front to back, which would require a seem on either side of the hood or center, or do you run the direction side to side to accommodate the width disregarding how it may look where it meets the sides?
