Disposing of discharged ink
Discussion in 'Think Green!' started by InCharged Printer, Nov 14, 2018.
  1. InCharged Printer
    InCharged Printer New Member
    4
    Oct 31, 2018
    Newark NJ
    Just wondering how everyone is getting rid of the discharged ink that collects in the bottle? I have been pouring it into a bucket with a lid but Im just about full and I would like to dispose properly.
    Thank you
  2. White Haus
    White Haus Formally known as RJPW..........
    574
    160
    43
    Apr 6, 2018
    Winnipeg
    We've contacted a waste disposal/environmental company to try to properly dispose of our solvent/UV ink in the past. Their minimum was something like a 100 gal drum for around $250 (they drop off the drum, we fill up, they pick up when full) so for now we're just stock piling it until we're close to filling one.
  3. Gino
    Gino Premium Subscriber
    33,331
    2,328
    113
    Jun 7, 2006
    PA
    What kinda ink ?? Latex, solvent, eco sol, vegetable..... ?? According to a lotta people on this forum, most of these inks are safe, so I imagine you could almost drink them or at least use them for a mixer.
    Once a year, our local baseball stadium has a hazardous waste drive and they take anything up to a 55 gal drum of anything. No questions asked. They dispose of it legally.
  4. Solventinkjet
    Solventinkjet DIY Printer Fixing Guide
    4,192
    784
    113
    Aug 2, 2011
    Denver, CO
    Pour it into some clumping cat litter and wait until it dries. Then dump it in the trash. Essentially, they want the toxins to go into the air instead of the ground where it can contaminate ground water. Once the solvents evaporate, all you have is a bunch of cat litter and pigment.
    • Agree Agree x 3
    • Like Like x 1
  5. Gino
    33,331
    2,328
    113
    Jun 7, 2006
    PA
    If that's the case, then why do they say certain inks are eco friendly to the environment in situations like schools, hospitals and food places ?? Those inks have certainly dried and have gassed off and maybe even covered with a laminate. However, you cannot put just any ol' ink into those areas. So, if your waste canister is full of solvent or whatever non-conforming ink(s), isn't it still doing damage to the environment and/or air ??
    I'm not starting an argument or trying to be obtuse, just what I've been told over the years. Years ago, when cleaning out a spray gun or whatnot, that scenario was true, but I've been told the inks are a different story. Kinda like taking the lead outta paint, I imagine.
  6. gabagoo
    gabagoo Major Contributor
    5,726
    105
    63
    Oct 10, 2006
    Vaughan, Ontario
    Why bother with kitty litter which makes more waste...how about just spreading it all in your dumpster and allow all the discarded backing paper , ruined prints and premask and coro bits absorb it..... I don't do that but curious as why we shouldn't as over a few days it will basically adhere to whatever is in there and dry out....
  7. Solventinkjet
    4,192
    784
    113
    Aug 2, 2011
    Denver, CO
    That's true. Kitty litter is just what I have been seeing people use forever. I think it's just cheap and convenient but your idea would probably work as well.
  8. unclebun
    unclebun Very Active Member
    I contacted our state Department of Natural Resources, and we actually have a requirement that paints and inks be poured into an adsorbent (kitty litter) and after drying/solidifying it is disposed in solid waste collection (the dumpster). It cannot be poured into the trash. So we keep a foil turkey roasting pan with kitty litter in it. We start out just covering the bottom with kitty litter, and as it gets soaked up with ink, we add more litter. It will generally work for 4 bottles worth of ink before we need to toss it.
  9. Solventinkjet
    4,192
    784
    113
    Aug 2, 2011
    Denver, CO
    Most of the time when you see eco in front of an ink brand it means economical not eco friendly. They kind of trick people with that. I have one customer who makes a product specifically for kids and they had their product tested in a lab. It's printed with a Roland using eco-sol ink on Arlon vinyl. The biggest concern the lab brought up was actually the vinyl and laminate believe it or not. They said the dry ink was fine but the phthalates in the vinyl and lam could be harmful to children. They ended up having to switch to cast vinyl on everything which just about tripled their cost. I would think the inks they use for hospitals etc is most likely water based but I'm not 100% sure on that.
  10. Modern Ink Signs
    Modern Ink Signs Premium Subscriber
    531
    132
    43
    Jun 27, 2008
    Waukesha, WI
    Cheap clumping kitty litter
    We use an empty container to start. Pour in the ink them some litter. Repeat until full and then throw into the dumpster.
    Quick and easy
  11. TimToad
    TimToad Very Active Member
    2,568
    635
    113
    Jun 13, 2013
    CA
    Most community's waste management companies host annual or semi-annual toxic waste drop off days. We keep our inks in the sealed jugs that our isopropyl alcohol comes in and then drop off them off at those events for free or low cost.
  12. unclebun
    The only testing/certification available for inks used indoors is UL's Greenguard/Greenguard Gold program. It uses standards based on Washington State (Greenguard) and California (Greenguard Gold) regulations for VOC's, heavy metals, etc. HP has made much noise over being Greenguard Gold certified with their latex inks, implying that if you want to make graphics for hospitals or schools you should be using their printers. However, Eco-solvent inks are usually also Greenguard Gold certified (https://www.rolanddga.com/blog/2016/06/02/21/11/eco-solvent-ink-vs-latex-ink) "The claim that latex is an eco-friendly option, while eco-solvent is the choice for the less environmentally conscious is simply not true. In reality, Roland Eco-Sol Max inks are Greenguard Gold-Certified for low VOC’s and indoor safety, the same as latex inks."
    In reality, the Eco- in eco-solvent ink DOES mean ecological. The old "true solvent" printers used solvents which were hazardous to the operator of the printer, and had to be externally vented and preferably isolated from humans. The eco-solvent inks do not contain solvents which are hazardous in typical workplace exposure.
  13. Solventinkjet
    4,192
    784
    113
    Aug 2, 2011
    Denver, CO
    I'm sorry to say that this isn't true. There are absolutely solvents in eco-sol inks and they cause cancer and birth defects. After the ink is dry I believe everything you said is true but when it's a liquid, and also breathing in it's vapors, it absolutely is hazardous to your health.
    • Agree Agree x 1
  14. chrisphilipps
    chrisphilipps Merchant Member
    652
    18
    18
    Jun 5, 2009
    Wharton, NJ
    I am in Morris County NJ only about 30 to 40 minutes from Newark, NJ, where the OP's profile says they are located. I can tell you that the county sent an investigator to all major industrial / commercial developments in the county to see how things like ink were disposed of. We asked him about the cat litter and was told if they caught anyone doing this they would get a fine. We us Veolia to remove the waste ink when we fill up a 55 gallon drum. I believe that the cost is somewhere around $250.00 and that includes getting a replacement drum.
    • Like Like x 1
    • Agree Agree x 1
    • Informative Informative x 1
  15. DerbyCitySignGuy
    DerbyCitySignGuy Very Active Member
    1,033
    296
    83
    Dec 12, 2013
    Kentucky
    The MSDS for your inks should have a "disposal consideration" section.
  16. unclebun
    Every state has different rules. Every waste generator needs to find out what their state requires.
  17. unclebun
    Mine says "dispose in accordance with applicable regulations"
    • Hilarious! Hilarious! x 1
  18. unclebun
    They do have solvents. But they are not hazardous in typical workplace exposure, which means the vapor that enters the room air during normal use. Here's a cut and paste from the MSDS for Epson Ultrachrome GS3 ink:
    Safety Data Sheet
    HMIS rating:
    3. COMPOSITION/INFORMATION ON INGREDIENTS
    Substances
    N.A.
    Mixtures
    Hazardous components within the meaning of 29 CFR 1910.1200 and related classification:
    65% ~ 80% 1-ethoxy
    -2-(2-
    methoxyethoxy)ethane
    CAS: 1002-67-1, EC: 213-690-5
    B.6/4 Flam. Liq. 4 H227
    10% ~ 12.5% gamma-Butyrolactone
    CAS: 96-48-0, EC: 202-509-5
    The product is not classified as dangerous according to OSHA Hazard Communication
    Standard (29 CFR 1910.1200).
    5% ~ 7% (2-Methoxymethylethoxy)propanol
    CAS: 34590-94-8
    1% ~ 3% Carbon black
    CAS: 1333-86-4, EC: 215-609-9
    Standard (29 CFR 1910.1200)."
    So one is listed as flammable. The others are listed as not dangerous according to OSHA Hazard Communication Standard.
    Now, there are indeed people who believe that there is no safe level of any chemical, and so on, but if we work that way, we would never paint or print anything.
  19. DerbyCitySignGuy
    1,033
    296
    83
    Dec 12, 2013
    Kentucky
    Haha! That's not particularly helpful then, sorry.
  20. bob
    bob Major Contributor
    5,274
    306
    83
    Nov 4, 2005
    earth
    Just toss it out somewhere. You're not going to destroy civilization. History will proceed totally unaffected regardless of what you do with it.
    • Disagree Disagree x 2
