Click to Support Signs101 ...
What is the standard out there for banners and hemming the sides. Are shops hemming all 4 sides on all size banners or just large banners that will be up for a long time? Im just using hem tape, not sewing.
We do all sides, and grommet top and sides. I've ordered some bigger ones from sub's and they only grommet two sides...then the customer brings it back.
We sew all four sides. We have an industrial sewing machine, it has paid for itself
1,000 times. People that do not hem, well that is a lower class of work than we like to put out.
Tape hem all 4 sides. Looks more professional than just top and bottom, plus uses very little tape & time to do. Grommets every 2', exception is on 36" width, then a grommet goes at 18".
I'm considering an industrial sewing machine. Mosh... what brand do you use and how much actual working space do you truly need?
Tape hem all 4 here and grommet- unless very temp then a piece of power tape on the back to reinforce grommets. Only tape failure I have had was
a pole pocket hung at the top of an arena with no grommets. I assume it
got real hot up there- probably would have held with a few grommets for
mechanical bonding.
