Does ACM / ePanel Need A Backer Sheet For Billboards?
Discussion in 'General Signmaking Topics' started by player, Apr 20, 2020.
  1. player
    player Major Contributor
    4,915
    189
    63
    Apr 24, 2006
    Toronto
    If I make an 8' x 12' billboard using 6mm (1/4") aluminum composite sheets, and have 2" x 6" crossers, do have to use plywood behind the ACM or can I screw it directly to the 2" x 6" boards?
    Any tips? Do the screws want to pull through the sheets? Do you use silicone or Lexel to adhere the sheets to the crossers?
  2. Texas_Signmaker
    Texas_Signmaker Very Active Signmaker
    4,609
    1,704
    113
    Oct 21, 2016
    Frisco, TX
    6mm is good enough to handle it on it's own. Just make sure you use plenty of of horizontal stringers... maybe every 2'.
    • Like Like x 1
  3. Gino
    Gino Premium Subscriber
    33,487
    2,384
    113
    Jun 7, 2006
    PA
    • Is this thing gonna be free standing ??
    • What's a crosser ??
    • how high in the air ??
    • Are you installing it ??
    • Which way is 8' and which way is the 12' ??
  4. Billct2
    Billct2 Major Contributor
    7,483
    650
    113
    Mar 12, 2005
    New England
    Depends on how far apart your "crossers" are. If you are concerned about fasteners pulling thru use some washer head fasteners, like the one used for metal siding/roofing.
    • Agree Agree x 1
  5. unclebun
    unclebun Very Active Member
    Your horizontal stringers can be just 2x4's. Every 2' vertically. We use screws called truss washer lath screws. No plywood. No adhesive. Don't have a picture of the back, but you can see the number of screws on the attached picture of this 8'x8'. This sign is 3mm MaxMetal. You can see in the photo this sign sits at the top of a ridge over a lake, where there is a lot of wind. No problems with panel bending or falling off. On this one we did use a 2x6 where the penals butt since there would be two rows of screws there. The Enclaves rider.jpg
  6. Gino
    33,487
    2,384
    113
    Jun 7, 2006
    PA
    Outta curiosity...... why didn't you try to at least hide the screws somewhat ??
    • Agree Agree x 2
    • Like Like x 1
  7. unclebun
    You can't see them to any appreciable degree when you are driving down the road. I was taught back when I first started in signs, "Are you going to notice a fly sitting on a billboard?" This photo's lighting highlights the screws really well, which is why I chose the photo. Plus it's a real estate sign. We do sometimes paint the screw heads when they are meant to be permanent signs for a business.
    • Like Like x 1
    • Agree Agree x 1
  8. unclebun
    Hah! Just opened an email that the development on that sign has a new realtor partner and we're going to be taking it down and changing the design of the sign now. That sign went up in December, we're taking it down in April. That's why I didn't try hiding the screws.
    • Hilarious! Hilarious! x 1
  9. Gino
    33,487
    2,384
    113
    Jun 7, 2006
    PA
    That fine and dandy, however I was taught differently. Looking at that ahead of time would tell me I'd have so many black screws, so many maroon, so many white and a few green. I'd put them into a styrofoam board, and spray them the colors needed. Take about 5 minutes total with a rattle can. I do it for every job that goes out. I already have a few hundred painted white and black, as those are very common colors.
    An 8'x 8' is hardly what I call a billboard. Might be splitting hairs, but your picture has a brochure box on it, which means people are gonna be coming right up to it, so they'll see your flies and even the flysh!t left behind, let alone, just to look at the plot plans.
    • Agree Agree x 2
    • Like Like x 1
  10. unclebun
    We do the same except we stick the screws into cardboard because the paint dissolves styro. And I have lots of discarded boxes but hardly ever any styrofoam.
  11. player
    4,915
    189
    63
    Apr 24, 2006
    Toronto
    Yes
    The horizontal boards behind the sign that connect the posts and give the sign face something to be screwed to.
    12' in the air.
    Yes.
    8' high, 12' wide.
  12. player
    4,915
    189
    63
    Apr 24, 2006
    Toronto
    Thank you for your suggestions. I always countersink the heads so they are flush and then I will paint them or precut vinyl circles to cover the heads. I also don't like to see screw heads on a face.
