Does anybody have a vinyl slitter?
RRP_Jac
I have a 24 inch roll of Oracal 651 I need cut down to 6 inch sections. Willing to pay can anyone help me out or point me in the right direction? Thanks
netsol
i would assume that can be done with a chop saw with a fine tooth blade, after wrapping the roll with several layers of tape
Old Timer
In my area I have a company called Kraft wrap which makes and cut rolls of kraft and butcher paper. I used to take 54" rolls of vinyl and have them cut into various widths. precise and economical. check in your area and see if you can locate a converter
myront
CorelDRAW is best
laminator take-up reel with homemade clamp on box cutter slicer. Works like a champ. Also used to trim off excess laminate from edge of rolled prints.
InstantOneMedia
We used to use a 96 tooth blade with our chop saw, but found an 8 tooth hardy board blade works much better and gives a cleaner cut.
myront
CorelDRAW is best
Any chance you could share a picture of this setup?
I had our print/laminating tech walk me thru the process. It's not as user friendly as I thought. Seems you have to physically hold the apparatus in place braced against wherever you set the position of the roll bump stop.
