I don’t remember the name, but I had this one and don’t recommend it for cutting sign material. It’s not very “heavy duty”. The four tracks are soft, lightweight aluminum and they eventually get loose and unaligned at the joints with frequent use resulting in a wavy or jagged cut. There is just a little plastic rod that joins the tracks. Also, the tracks are very lightweight, so if you’re not pressing down firmly with your weight while cutting, your cut will begin to skew on you because the tracks will bend at the joints. Also, the cutter itself is cheap feeling and frequently got jammed when pushing down to expose blade. I literally had to use both hands and pry them apart on several occasions. I tossed it in the trash and got a couple nice heavy duty safety rulers now to use with a utility knife. Life is much better now!
