Does anybody know what brand this cutter is?
Joshua Barnes
I'm trying to find this specific cutter to purchase for my shop, but I'm striking out left and right. It comes with tracks that can be pieced together for custom sizes. Used to use one, but can't find it online anywhere. Or, if anyone has any suggestions about cutting 1/2in ultra board without tearing up the edges, that would be helpful too.
+1 keencutter
i don't think they come as multiple tracks that fit together to become longer, just standard lengths they offer. its just extrusion, with a proprietary pattern/track built-into it that the cutting attachment is designed to ride on. ...tho' i'm sure you can contact and order custom lengths if desired.
Joshua Barnes
+1 keencutter
That's all I'm seeing. That specific one in the photo comes in a bag with 4 tracks that can be interconnected, but I'm not finding one similar anywhere.
JERHEMI
I don’t remember the name, but I had this one and don’t recommend it for cutting sign material. It’s not very “heavy duty”. The four tracks are soft, lightweight aluminum and they eventually get loose and unaligned at the joints with frequent use resulting in a wavy or jagged cut. There is just a little plastic rod that joins the tracks. Also, the tracks are very lightweight, so if you’re not pressing down firmly with your weight while cutting, your cut will begin to skew on you because the tracks will bend at the joints. Also, the cutter itself is cheap feeling and frequently got jammed when pushing down to expose blade. I literally had to use both hands and pry them apart on several occasions. I tossed it in the trash and got a couple nice heavy duty safety rulers now to use with a utility knife. Life is much better now!
nomadme
Best ruler/cutter combo ever, you will never use anything else. Includes a finger guard. It slides down a track on it, extremely smooth and the blade can be switch on the left and right side.
Ruler
https://s3.amazonaws.com/fellers/production/uploads/Sooper_3.png
https://s3.amazonaws.com/fellers/production/uploads/Sooper_2.png
Cutter:
https://s3.amazonaws.com/fellers/production/products/2702.png
What is the name of this product? Possible link to the seller?
Kind a seem like toyish, but I kind a like its simplicity.
